VSavi3
3 years agoNot able to do fitting design with Quartus 22.1
Hi, I am able to fit the attached design with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition. However, I can fit the design with ease in Version 19.1.0 Build 670 09/22/2019 SJ Standard ...
ShengN_altera
3 years agoHi,
I had compared between the v19.1 and v22.1 .qsf and noticed there're differences between the v19.1 and v22.1 .qsf. in terms of partition and logic lock region. Is that the design used in v19.1 and v22.1 are exactly the same? Is that the partition and logic lock region are exactly the same as well? If no, then that's normal to get different compilation result for both v19.1 and v22.1.
Sheng
