13 years ago
Node * determined to be a clock
TQ gives me these warnings:
--- Quote Start ---
Warning: Node: current_state.r2 was determined to be a clock but was found without an associated clock assignment.
Warning: Node: current_state.idle was determined to be a clock but was found without an associated clock assignment.
--- Quote End ---
In fitter report (control signals) I see that they are Latch enable signals for whom fitter uses global clock network.
Before continuing I think i should explain my design a little bit. The troubling part is a SRAM controller - a simple state machine. In the RTL viewer the state machines logic is masked in a block, with outputs corresponding to each state - idle, r1, r2, w1, w2.
But only the r2 acts directly as enable signal to some of the latches, but not the idle signal. So I don't think they're at fault, but honestly I'm pretty lost (not to mention the naming of nodes, nets, etc :/):
When I choose to locate these signals in RTL netlist from Fitter report (control signals), it points to the state machine block, but not to any nets (unlike with other control signals).
Also, if they actually were latch enable signals, why would fitter use global clock network for them?
I'm not sure if I have provided all the necessary information, so please ask if something additional is needed (like the code itself or smth).
Thanks in advance!
    --- Quote Start ---
    I didnt read it properly first time. The problem comes because you're connecting data_from_ram and DataIO to themselves when in certain states - this is where the latches come from. Latches are bad because you cannot analyse them with timing analyse and they are highly affected by temperature and subject to glitches.
    So it is best not to use latches. Either connect them to a constant or something else in the others case, or synchronise them (as would be the prefered option). With synchronised registers for these pins they can be placed in the fast IO registers to make the output timings easier to control.
    --- Quote End ---
    I seem to have a similar problem, being rather unexperienced with Quartus. I too get the warning:
    Warning (332060): Node: ... was determined to be a clock but was found without an associated clock assignment.
    I am writing a controller to process the inputs from the MegaWizard Virtual JTAG node (passed from a PC to the FPGA with the tcl-command "device_virtual_dr_shift"). The value I am interested in is called "challenge". I need to shift it into the controller bit by bit but at the same time I want it to be available at an output of the controller.
    Here is the relevant part of my code:
    entity controller is
       generic
          challenge_width   : integer := 8
       port
          ir_in           : in std_logic_vector(7 downto 0);
          tck_in         : in std_logic;
          tdi_in         : in std_logic;
          shift_dr_in      : in std_logic;
          challenge_out      : out std_logic_vector((challenge_width-1) downto 0);
    end controller;
    architecture arch of controller is
       -- Instruction codes.
       constant C_PUSH_CHALLENGE   : std_logic_vector(7 downto 0) := "00000001";
       -- Register.
       signal challenge_dr   : std_logic_vector((challenge_width-1) downto 0);
    begin
       challenge_out <= challenge_dr;
       process(tck_in)
       begin
          if rising_edge(tck_in) then
             if ir_in = C_PUSH_CHALLENGE and shift_dr_in = '1' then
                challenge_dr <= tdi_in & challenge_dr((challenge_width-1) downto 1);
             end if;
          end if;
       end process;
    end arch;
    As I said above, challenge_dr is causing the warnings:
    Warning (332060): Node: controller:control|challenge_dr[0] was determined to be a clock but was found without an associated clock assignment.
    Warning (332060): Node: controller:control|challenge_dr[4] was determined to be a clock but was found without an associated clock assignment.
    Any ideas how to handle this?
    Linus
    --- Quote Start ---
       generic
       port
    end controller;
       -- Register.
    begin
       process(tck_in)
       begin
             end if;
          end if;
       end process;
    end arch;
    Linus
    --- Quote End ---
    your problem isn't in the piece of code given above. challenge_dr must have been used somewhere else as clock.
    Hello Kaz,
    and thanks for your reply!
    challenge_dr is just used as internal signal in controller. As my code snippet shows, it is passed out of controller through challenge_out.
    challenge_out[3..0] and challenge_out[7..4] are each used as select-inputs of two 16-bit MUXes.
    Interestingly, I only get the warning for challenge_dr[0] and challenge_dr[4].
    So is the MUX causing the waring? Here is its code:
    --	MUX Parameterized Megafunction
    INCLUDE "lpm_mux.inc";
    PARAMETERS
    	WIDTH,
    	WIDTHS = CEIL(LOG2(WIDTH))
    SUBDESIGN mux
    	data	: INPUT;
    	sel	: INPUT;
    	result				: OUTPUT;
    BEGIN
    	result = lpm_mux(.data=data, .sel=sel)
    		WITH (LPM_WIDTH = 1, LPM_SIZE = WIDTH, LPM_WIDTHS = WIDTHS);
    	IF !USED(result) GENERATE
    		result = GND;
    	END GENERATE;
    END;
    --- Quote Start ---
    Hello Kaz,
    PARAMETERS
        WIDTH,
    SUBDESIGN mux
        data    : INPUT;
        sel    : INPUT;
        result                : OUTPUT;
    BEGIN
            result = GND;
        END GENERATE;
    END;
    --- Quote End ---
    challenge_out is wired to challenge_dr and is viewed as same node for clocking purpose. So check that challenge_out is used as clock
    --- Quote Start ---
    --- Quote End ---
    You are right! challenge_out goes as select into the MUX. The MUX selects the outputs of different ring oscillators whose edges are counted by a counter. (See the attached image for explanation of Ring-Oscillator Physically Unclonable Functions.) The counter's input is indeed defined as clock:
    entity counter is
        port (
                -- Input ports
                clk                : in std_logic;
                reset             : in std_logic;
                start_counter    : in std_logic;
                stop_counter    : in std_logic;
                -- Output ports
                count : out std_logic_vector(127 downto 0)
    end entity counter;
    architecture logic of counter is
        signal tmp_count        : std_logic_vector(127 downto 0) := (others => '0');
        signal run_counter    : std_logic := '0';
    begin
            process(clk,reset)
            begin
                if reset = '1' then
                    tmp_count <= (others => '0');
                elsif rising_edge(clk) then
                    if run_counter='1' then
                        tmp_count <= tmp_count + 1;
                    end if;
                end if;
            end process;
            process(start_counter,stop_counter)
            begin
                if start_counter='1' then
                    run_counter<='1';
                elsif stop_counter='1' then
                    run_counter<='0';
                end if;
            end process;
            count <= tmp_count;
    end architecture logic;
    So should I ignore the warning or is there a way to suppress it via more explicit code?
    Linus
    you might do better using clock mux core of altera as otherwise you get timing problems.
    I should also say that the mux may not be the issue rather it is the gated clock(from counters). You can use one fast proper clock then use counters as clock enable at its rate.
