12 years ago --- Quote Start --- I didnt read it properly first time. The problem comes because you're connecting data_from_ram and DataIO to themselves when in certain states - this is where the latches come from. Latches are bad because you cannot analyse them with timing analyse and they are highly affected by temperature and subject to glitches. So it is best not to use latches. Either connect them to a constant or something else in the others case, or synchronise them (as would be the prefered option). With synchronised registers for these pins they can be placed in the fast IO registers to make the output timings easier to control. --- Quote End --- Hello, I seem to have a similar problem, being rather unexperienced with Quartus. I too get the warning: Warning (332060): Node: ... was determined to be a clock but was found without an associated clock assignment. I am writing a controller to process the inputs from the MegaWizard Virtual JTAG node (passed from a PC to the FPGA with the tcl-command "device_virtual_dr_shift"). The value I am interested in is called "challenge". I need to shift it into the controller bit by bit but at the same time I want it to be available at an output of the controller. Here is the relevant part of my code:
entity controller is
generic
challenge_width : integer := 8
port
ir_in : in std_logic_vector(7 downto 0);
tck_in : in std_logic;
tdi_in : in std_logic;
shift_dr_in : in std_logic;
challenge_out : out std_logic_vector((challenge_width-1) downto 0);
end controller;
architecture arch of controller is
-- Instruction codes.
constant C_PUSH_CHALLENGE : std_logic_vector(7 downto 0) := "00000001";
-- Register.
signal challenge_dr : std_logic_vector((challenge_width-1) downto 0);
begin
challenge_out <= challenge_dr;
process(tck_in)
begin
if rising_edge(tck_in) then
if ir_in = C_PUSH_CHALLENGE and shift_dr_in = '1' then
challenge_dr <= tdi_in & challenge_dr((challenge_width-1) downto 1);
end if;
end if;
end process;
end arch;
As I said above, challenge_dr is causing the warnings: Warning (332060): Node: controller:control|challenge_dr[0] was determined to be a clock but was found without an associated clock assignment. Warning (332060): Node: controller:control|challenge_dr[4] was determined to be a clock but was found without an associated clock assignment. Any ideas how to handle this? Thanks, Linus
