12 years ago --- Quote Start --- Hello, I seem to have a similar problem, being rather unexperienced with Quartus. I too get the warning: Warning (332060): Node: ... was determined to be a clock but was found without an associated clock assignment. I am writing a controller to process the inputs from the MegaWizard Virtual JTAG node (passed from a PC to the FPGA with the tcl-command "device_virtual_dr_shift"). The value I am interested in is called "challenge". I need to shift it into the controller bit by bit but at the same time I want it to be available at an output of the controller. Here is the relevant part of my code:
entity controller is
generic
challenge_width : integer := 8
port
ir_in : in std_logic_vector(7 downto 0);
tck_in : in std_logic;
tdi_in : in std_logic;
shift_dr_in : in std_logic;
challenge_out : out std_logic_vector((challenge_width-1) downto 0);
end controller;
architecture arch of controller is
-- Instruction codes.
constant C_PUSH_CHALLENGE : std_logic_vector(7 downto 0) := "00000001";
-- Register.
signal challenge_dr : std_logic_vector((challenge_width-1) downto 0);
begin
challenge_out <= challenge_dr;
process(tck_in)
begin
if rising_edge(tck_in) then
if ir_in = C_PUSH_CHALLENGE and shift_dr_in = '1' then
challenge_dr <= tdi_in & challenge_dr((challenge_width-1) downto 1);
end if;
end if;
end process;
end arch;
As I said above, challenge_dr is causing the warnings: Warning (332060): Node: controller:control|challenge_dr[0] was determined to be a clock but was found without an associated clock assignment. Warning (332060): Node: controller:control|challenge_dr[4] was determined to be a clock but was found without an associated clock assignment. Any ideas how to handle this? Thanks, Linus --- Quote End --- your problem isn't in the piece of code given above. challenge_dr must have been used somewhere else as clock.
