12 years ago --- Quote Start --- challenge_out is wired to challenge_dr and is viewed as same node for clocking purpose. So check that challenge_out is used as clock --- Quote End --- You are right! challenge_out goes as select into the MUX. The MUX selects the outputs of different ring oscillators whose edges are counted by a counter. (See the attached image for explanation of Ring-Oscillator Physically Unclonable Functions.) The counter's input is indeed defined as clock:
entity counter is
port (
-- Input ports
clk : in std_logic;
reset : in std_logic;
start_counter : in std_logic;
stop_counter : in std_logic;
-- Output ports
count : out std_logic_vector(127 downto 0)
end entity counter;
architecture logic of counter is
signal tmp_count : std_logic_vector(127 downto 0) := (others => '0');
signal run_counter : std_logic := '0';
begin
process(clk,reset)
begin
if reset = '1' then
tmp_count <= (others => '0');
elsif rising_edge(clk) then
if run_counter='1' then
tmp_count <= tmp_count + 1;
end if;
end if;
end process;
process(start_counter,stop_counter)
begin
if start_counter='1' then
run_counter<='1';
elsif stop_counter='1' then
run_counter<='0';
end if;
end process;
count <= tmp_count;
end architecture logic;
So should I ignore the warning or is there a way to suppress it via more explicit code? Thanks, Linus
