11 years ago
NO clock event, but signal changes anyway!
In a nutshell, something weird is going on in my simulation...
Clearly my code states that upon a rising_edge of nDB_BUF_EN then various outputs are latched. However I have seen the clocking signal nDB_BUF_EN to be stable (at logic 1) BUT the latched outputs change!
How could this be?
  proc_IOControlDBBusLatch : PROCESS (nRST, nDB_BUF_EN)
  BEGIN
    IF nRST='0' THEN
      zb2D7_FrameBlank   <= '0';
      zb2D6_LineBlank    <= '0';
      zb2D5_CPU_Access   <= '0';
      zb2D4_AltGREENsel  <= '0';
      zb2D3_BANK3_CASsel <= '0';
      zb2D2_BANK2_CASsel <= '0';
      zb2D1_CassMotorEn  <= '0';
     zb2D0_SpeakerEn    <= '0';
    ELSIF RISING_EDGE(nDB_BUF_EN) THEN
      --Latch data from the common databus
      zb2D7_FrameBlank   <= D_7_0(7);
      zb2D6_LineBlank    <= D_7_0(6);
      zb2D5_CPU_Access   <= D_7_0(5);
      zb2D4_AltGREENsel  <= D_7_0(4);
      zb2D3_BANK3_CASsel <= D_7_0(3);
      zb2D2_BANK2_CASsel <= D_7_0(2);
      zb2D1_CassMotorEn  <= D_7_0(1);
      zb2D0_SpeakerEn    <= D_7_0(0);
    END IF;
  END PROCESS proc_IOControlDBBusLatch;
So my question is, under what possible circumstances can the outputs change (latch) if nDB_BUF_EN is NOT changing??? I see no 'glitch' on nDB_BUF_EN either - there is NO rising_edge event!
Thanks in advance for any insights,
Andy
    Wow, thanks for the VERY helpful insights / suggestions everyone. Excellent responses on this forum as usual.
    Zooming in showed no glitch. You can advance to 'next transition' in my simulator (for any selected signal) and there is NO transition in this area that would drive a change in the process.
    To solve the problem, as suggested, I now clock the latch using the system clock thus:
      proc_IOControlDBBusLatch : PROCESS (nRST, M4MHz)
      BEGIN
        IF nRST='0' THEN
        ELSIF RISING_EDGE(M4MHz) THEN
          IF nDB_BUF_EN='1' THEN
          END IF;
        END IF;
    The D_7_0(7 DOWNTO 0) signal(s) remains stable for the (total of 4) clocking pulses of M4MHz that is active for the above process when nDB_BUF_EN is at '1'.
    I am now searching through the rest of my code for any other similar processes implemented in this manner.
    Thanks again everyone!
    Andy
    PS,
    For the record (in case any of you were wondering WHY I chose to use a logic source as a clocking event) these signals are driven from a Z80 core (actually a T80 core from opencores). Everything appears to 'do it's stuff' apart from a few issues (like this one) I am trying (very slowly) to hunt down.
    You could have had a 1 delta wide pulse. They dont tend to show up on the waveform, but will cause a clock to happen.
    Hmmm. I am wondering now how such an event can be traced back to the source of the problem.
    A
    put some debug asserts in your code:
    process(nDB_BUF_EN)
    begin
      if rising_edge(nDB_BUF_EN) then
        report "a Rising edge on nDB_BUF_EN just occured"
          severity Failure; --or note or warning or error if you want simulation to continue
      end if;
    end process;
