Nios-II/Nios-V future on Intel FPGAs
Hi sstrell,
Thanks for providing the information on the 23.1 Lite version and Nios II.
Hi Jan,
What sstrell mentioned is correct, Nios II has been discontinued and users are advised to migrate to Nios V onwards. Did you test on 23.1 Quartus Lite Edition when you mentioned software flow on Nios V is not supported?
I will also check with our Intel university program coordinator to confirm on this.
Kian
- KianHinT_altera2 years ago
Hi Jan,
I've gotten the feedback from our Altera/Intel University program coordinator on this matter as per below:
Basically Nios V is available on Standard/Lite version 23.1 and currently they are working on the educational material around Nios V which will be available later this year.
The current stance is to stick with Nios II for now. Once Altera release the new materials for Nios V, then it would be up to the individual professors to decide whether to continue using Nios II or move to Nios V. However do note that in near future, Altera will only be supporting Nios V in the university program .
Kian
- Jan10002 years ago
Hi sstrell, khtan,
thank you for your replies. I have tested it with latest 23.1 Lite version on Ubuntu OS and also on Windows 10. I went through AN985 (https://cdrdv2-public.intel.com/784469/an-784468-784469.pdf ) and in Software requirements there is specifically named "Intel Quartus Prime Pro Edition Software version 23.2" and here https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html#tab-blade-1-0 I have found that you mention RiscFree IDE only on Pro Editon tab and there is only Nios-II on Lite Edition tab. Therefore, I have probably misunderstood that Nios-V is not supported in Lite version.
There were other reasons to believe so:
1) in AN985 in section 1.2.3.1. Creating a Board Support Package, there is a flow to generate BSP, but in my Platform designer, I see no menu option File->New BSP (tested on both Ubuntu OS and Windows 10)
2) I have tried to create BSP via the command line tool niosv-bsp as described here https://www.intel.com/content/www/us/en/docs/programmable/743810/24-1/niosv-bsp-30520.html#xsf1640875330520__section_tcc_vdx_bsb , but I get "Error: Unrecognized switch <b>p</b>". Even if I tried to generate the BSP as described here https://www.intel.com/content/www/us/en/support/programmable/articles/000096537.html ), I still get errors (I have tested both -p and --quartus-project options).
From these I concluded that it is a problem of Lite version. I am happy to read that Nios-V is going to be supported.Please, do you have some recommendations on verified handbook / manual for Lite version? Is there another trick for niosv-bsp to generate the BSP?
Thank you.
Jan
Hi Jan,
Thanks for the information, let me investigate on our end why lite version Nios V is not there and get back to you later and the documents for nios V.
Kian
