mitsvoid
2 years agoNIOS II/e using FFT block floting point
Dear All, I hope you are doing well. I am working on an embedded project with Altera DE2-115, and I would like to ask if the Nios II/e processor can process the output from the FFT IP block in float...
- 2 years ago
It seems the processor can calculate floating point operations.
Below I attached Floating Point reference -
Related case for your reference -
Regarding NiosII with FFT IP, there is no design example so far.
Thank you.
Fathulnaim.
wwanalim_intel
Contributor
2 years agoHi,
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
