Asifa
1 year agoNIOS ii/e clock frequency differ from real-time running frequency.
I have created a Qsys circuit using Nios II/e, with a clock frequency of 50 MHz. Other peripherals are also connected, as shown in the attached photo. I wrote a program in Eclipse, and when I checked...
tehjingy_Altera
1 year agoHi
That is a huge difference in the delay.
Could you check if the actual clock that is supplying to the pin for clock is actually 50Mhz?
Even you are entering 50Mhz in the clock ip, does not mean that the clock is 50Mhz.
It would require an actual 50Mhz clock to the clock ip.
Jingyang, Teh
