IMura
2 years agoNCO's HEX not found by Quartus Pro in project
Hello, I have a project using an NCO on Quartus Pro 18.1. The project is organized as below: /proj---/syn/qproject | --/top/ -/modules--/nco ...
SyafieqS
2 years agoHi,
I can reproduce the issue. I will file the enhancement and fix for this. As mentioned the workaround should be feasible. You are encouraged to work on latest releases as we have lot of bug fix.
- IMura2 years ago
Hi Syafieq,
How will the fix be implemented?
While using the latest releases is what is encouraged, since our FPGA projects contain the HPS, upgrades to newer versions create bugs and for now, I don't have enough time to do all the testing, hence using the tried and tested version. Plus, our licence is only valid until a certain number of versions...
Thank you.
