IMura
2 years agoNCO's HEX not found by Quartus Pro in project
Hello, I have a project using an NCO on Quartus Pro 18.1. The project is organized as below: /proj---/syn/qproject | --/top/ -/modules--/nco ...
IMura
2 years agoIt is not blocking for now since the workaround is I copy the hex files into the working directory. However this is not a good solution so hopefully this issue can be resolved quickly.
Thank you.
