IMura
2 years agoNCO's HEX not found by Quartus Pro in project
Hello, I have a project using an NCO on Quartus Pro 18.1. The project is organized as below: /proj---/syn/qproject | --/top/ -/modules--/nco ...
sstrell
2 years agoI don't know much about that IP, but if it's like an on-chip RAM, did you associate the .hex file with the IP itself? A .hex is not a design file. It has to be associated with the IP that uses it and that's usually in the IP's parameter settings.
IMura
2 years agoThank you for your response.The onchip ram is used and configured by the IP itself. In the NCO IP generation parameters (Platform Designer), users do not have the possibility to point where the hex files are located.
Again, this problem only seems to affect the NCO IP. FIR II which also uses RAM and hex files work well.
