xxiao14
1 month agoMy signaltap test has some problem
When I use signaltap, sometimes it has a problem, there's a blank gap at the beginning and the signals can't be triggered(please see two examples in below pictures). It's not the code or design probl...
sstrell
1 month agoYes, let's see your trigger settings.
Regarding storage qualification, that lets you make the best use of the limited buffer space by keeping only the captured data samples that meet the criteria you specify. So for example, with the "input port" option you show in the screenshot, samples are only stored in the buffer if the signal you specify as the "input port" is active, essentially making that signal a write enable for the data buffer. Other options allow you to skip long periods of time where signals are not toggling (transitional) or create a full boolean condition as to when to capture data (conditional). All documented in the user guide.
