xxiao14
1 month agoMy signaltap test has some problem
When I use signaltap, sometimes it has a problem, there's a blank gap at the beginning and the signals can't be triggered(please see two examples in below pictures). It's not the code or design probl...
FvM
1 month agoHi,
shown waveforms are rather an example of trigger condition is fulfilled instantly than "doesn't trigger". Can you please show related trigger settings?
Generally speaking, triggering can be a problem if triggered waveform isn't synchronous to sampling clock, causing timing violation in Signaltap logic.
Regard Frank
