12 years ago
module top (SW[0]) complains but module top(SW) doesn't? Why?
I'm using Cyclone III on DE0, Quartus II.
I was wondering where/how are the groupings of SW[0] to SW[9] done and combined into one signal of 10 bits named SW?
Initially, I defined SW[0] to the appropriate pin myself and got no complaint.
Later, I used import on the default .qsf file from Altera website and I get the complaint "some pins have incomplete i/o assignment" if I try to use
module top (SW[0], LEDG[0])
instead of
module top (SW, LEDG)
I would just like to understand what is going on.
    Sorry maybe my question is no good. I'm looking at the DE0 schematic and it appears the name of the bus is SW/LEDG and contains [9:0].
    Can anyone confirm if it is possible to use module top(SW[0], LEDG[0]); input SW[0]; output LEDG[0]; ?
    Where I assign SW[0] and LEDG[0] to PIN_J6 and PIN_J1 respectively? The functionality desired is a simple assign LEDG[0] = SW[0]
    module top (
    input wire  SW,
    output wire  LED
    assign LED = SW;
    endmodule
    or
    module top (SW, LED);
    input  SW;
    output  LED;
    wire  LED;
    assign LED = SW;
    endmodule
    Having analysed your code with Quartus the Pin Planner will present you with two 10-bit busses for you to assign pins to.
    Alex
