Modifying PRBS Frequency in Stratix V
- 2 years ago
Hi Junsu,
I have explored and gone through your design, it seems currently 644.53125MHz is coming from an external source pin. If yes, then is it possible to change that clock? I don’t think. Currently you are using clock source of 625MHz which is fed as refclk to XCVR IP. So, if you change the clock accordingly you need to configure the clock source as well. Also, you need to change the Low Latency PHY Intel FPGA IP Configuration accordingly.
If you any questions or want to discuss further, please let me know we can have a call to discuss.
Thank you,
Kshitij Goel
Hi Junsu,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Kshitij Goel
