Modifying PRBS Frequency in Stratix V
- 2 years ago
Hi Junsu,
I have explored and gone through your design, it seems currently 644.53125MHz is coming from an external source pin. If yes, then is it possible to change that clock? I don’t think. Currently you are using clock source of 625MHz which is fed as refclk to XCVR IP. So, if you change the clock accordingly you need to configure the clock source as well. Also, you need to change the Low Latency PHY Intel FPGA IP Configuration accordingly.
If you any questions or want to discuss further, please let me know we can have a call to discuss.
Thank you,
Kshitij Goel
- Which Operating system you are using?
- Which Quartus Software version you are using?
- Which device (OPN) you are targeting?
- Which FPGA Development Kit you are using, if any?
Also, it will be good if you share your Quartus Project QAR.
Thank you,
Kshitij Goel
- DeadEnd2 years ago
Thank you for your reply.
Below is an answer you asked.
- Which Operating system you are using?> Window 11 Pro
- Which Quartus Software version you are using?> Quartus II 14.0
- Which device (OPN) you are targeting?> Stratix V (5SGXEA7N2F40C2
- Which FPGA Development Kit you are using, if any?> Please refer to above answers.
And How can I share my QAR file?
This is an open space, so it is difficult to post it, but if you have a way to share it, I'll share it to you.
