ModelSim/Questa does not include external IP repo files
Hello Altera Community
In Quartus Prime Pro 26.1 I'm doing a Tool -> RTL Simulation, for an Intel AI IP System.
Simulation fails with errors like "Module 'dot_bf16' is not defined"
These modules exists in my folder "ip_repo", which I placed next to my "quartus" project folder. C:\Users\mads\Desktop\test\ip_repo\altera_ai_ip\verilog\spatial_ip\
The generated top_level.sv instantiates (dot_bf16, relu, strm_wrap). But the simulation compile flow does not include their source files. Quartus simulation flow does not compile them.
I tried to editing them into spatial_first_run_msim_rtl_vhdl.do, but quartus regenerates it every run.
vlog -sv -work work C:/Users/mads/Desktop/test/ip_repo/altera_ai_ip/verilog/spatial_ip/dot/dot_bf16.sv
Platform Designer does not seem to have an "include external hdl" option
I also tried to copy the sv files into the simulation folder, but Quartus only compiles what its generated scripts explicitly list.
How do I fix this? Thanks in advance.
I think the error occurs because the files is encrypted. Perhaps it could give you an idea what might goes wrong.
I am not familiar with the Spatial IP simulation flow, so I would recommend following the user guide for guidance.
https://docs.altera.com/r/docs/863373/2026.1.1/fpga-ai-suite-handbook/simulating-an-fpga-ai-suite-ip
Richard Tan
- RichardT_altera
Have the Quartus able to run the Analysis & Synthesis successfully before you run RTL simulation?
> The Quartus will regenerate and overwrite the default .do file. If you would like to modify the .do file, copy & create a new name .do file, and run it directly in the Questa simulator tool.
Richard Tan- Mads_From_Denmark
Yes that worked!
Now I get a new error# ** Error: C:/Users/mads/Desktop/test/ip_repo/altera_ai_ip/verilog/spatial_ip/common/strm_wrap.sv(43): in protected region
- RichardT_altera
Richard Tan
