MAX+PLUS II License Issue
- 1 year ago
I can't help you with the MAX+PLUS stuff (why do you need to run ancient software instead of Quartus?), but for creating a license, you've selected a NIC ID (a MAC address tied to a network connection). As such, that has to be a 12 digit hex number. I've never heard of tying a license to a hard drive serial number.
- robbson251 year ago
Hello sstrell,
I have many projects created in "old" MAX+PLUS that's why I asked about license for it.
I will install Quartus and check if I can import my projects.
- jAlter1 year ago
@sstrell wrote:I can't help you with the MAX+PLUS stuff (why do you need to run ancient software instead of Quartus?), but for creating a license, you've selected a NIC ID (a MAC address tied to a network connection). As such, that has to be a 12 digit hex number. I've never heard of tying a license to a hard drive serial number.
Then you are too young, or at least you haven't used Quartus for so long ago
Older Quartus versions definitely used the Hard Disk serial number for licensing. Remember that at that time motherboards didn't use to come with a built-in NIC. I'm quite sure that, at least, Quartus 6 supported hard disk serial numbers. Don't remember when this changed.
