LVDS SERDES IP compile error in Stratix10, Quartus Prime Pro 20.3
I have a compile error in my Quartus 20.3 project that appears to be within the Intel-generated LVDS SERDES IP. Can you provide additional insight into what the following error indicates as root cause? I believe the complaint is about a connection within the Intel IP:
"The serial pin LVDSOUT for the LVDS SERDES IP instance dsi2_host_phy_top|phy_wrapper|tx_dphy_top|clk_lane_altera|lvds_0|core|arch_inst|channels[0].tx.serdes_dpa_isnt must be pulled up to the top level and cannot fan out to anything else."
This LVDS IP instance is configured as TX, 1 channel, SERDES factor=8 with external PLL.
Erin
I discovered that Quartus believes the LVDSOUT signal is being fanned out because it is not reading the Verilog HDL macro I've set for the project, corresponding to a Verilog `ifdef around the fanned out signal. So I need to modify the question to discover what the proper way is to set a Verilog define in Quartus 20.3. The method I used in Quartus 19.1 does not appear to work (Assignments -> Settings; Verilog HDL Input; Verilog HDL macro; Name: <Verilog define name>, Setting: 1)
- Ash_R_Altera
I am not able to reproduce the error for the directive usage. Quartus 20.3 and S10 device is able to consider the macro definition correctly.
The error may be due to the `else part where tool might be routing the LVDS output to other glue logic and not the pin, because that it is the only possible way it is expecting.
- ErinS
It appears that setting the Verilog macro wasn't being saved. There is a separate button to do this in the GUI, not just the OK/Apply buttons. Once I was able to confirm it was saved, the fanout issue was resolved. Thank you - Erin
- BikshuNaik
Hi ErinS,
I am having the same error as you mentioned in your post, while instantiating the LVDS SERDES IP. I could not understand what is the macro you set for this IP and what have you mentioned in the <verilog define name> (Assignments -> Settings; Verilog HDL Input; Verilog HDL macro; Name: <Verilog define name>, Setting: 1).
So can you please help me.
thank you.
- BikshuNaik
Can someone please help me with the solution for the "The serial pin LVDSOUT for the LVDS SERDES IP instance dsi2_host_phy_top|phy_wrapper|tx_dphy_top|clk_lane_altera|lvds_0|core|arch_inst|channels[0].tx.serdes_dpa_isnt must be pulled up to the top level and cannot fan out to anything else." issue. What is the macro i should set for this LVDSOUT signal so that it won't be consider being fanned out.
