LVDS SERDES IP compile error in Stratix10, Quartus Prime Pro 20.3
I am not able to reproduce the error for the directive usage. Quartus 20.3 and S10 device is able to consider the macro definition correctly.
The error may be due to the `else part where tool might be routing the LVDS output to other glue logic and not the pin, because that it is the only possible way it is expecting.
- ErinS5 years ago
It appears that setting the Verilog macro wasn't being saved. There is a separate button to do this in the GUI, not just the OK/Apply buttons. Once I was able to confirm it was saved, the fanout issue was resolved. Thank you - Erin
- BikshuNaik4 years ago
Hi ErinS,
I am having the same error as you mentioned in your post, while instantiating the LVDS SERDES IP. I could not understand what is the macro you set for this IP and what have you mentioned in the <verilog define name> (Assignments -> Settings; Verilog HDL Input; Verilog HDL macro; Name: <Verilog define name>, Setting: 1).
So can you please help me.
thank you.
