17 years agoLVDS pin error on cyclone III
Hi
I am making a design with the cyclone III starter kit and I want to add a LVDS transmitter interface for a display, but I get the following error: Error: Non-differential I/O pin flash_ssram_d[0] in pin location H3 and pad 18 too close to differential I/O pin tft_out_y[0] in pin location H2 and pad 15 -- pins must be separated by a minimum of 5 pads Do I need to separate my LVDS pins by a minimum of 5 pads from non-differential IO pins? This sounds like quite a lot. It is almost impossible to do this if I want to keep the memory interfaces etc. I have added an assignment for a "Fast Output Register" for my LVDS pins in the assignment editor. Is there anything else I need to do to place my LVDS pins closer to the non-differential IO pins? Thanks Tom
