Altera_ForumHonored Contributor18 years agoLVDS pin error on cyclone III Hi I am making a design with the cyclone III starter kit and I want to add a LVDS transmitter interface for a display, but I get the following error: Error: Non-differential I/O pin flash_...Show More
Altera_ForumHonored Contributor15 years ago --- Quote Start --- the only problem is the interference ? --- Quote End --- Yes. It doesn't change anything except disabling the distance rule check.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
