16 years ago --- Quote Start --- Hello, You can assign 0 MHz toggle rate to pins to make Quartus fitter ignore them in placement rules check. If the respective pins actually are toggling, they probably may cause interferences. Regards, Frank --- Quote End --- Hi Frank, I have a similar problem related to this but in my case the single-ended control signal that is too close to an LVDS dif pair is a very infrequent signal that seldom changes state; so I think calling it 0MHz in my case makes sense. Anyway, my question is exactly where can I assign the toggle rate? Thanks MAX
