David_MD_KIM's avatar
David_MD_KIM
7 years ago
LVDS IO error
Hi, again
I try very simple case as attached.
But It is same error result.
Please advice how to interface lvds IO input by primitives
  • SreekumarR_G_Intel's avatar
    SreekumarR_G_Intel
    Can you give me the device part number ? Did you check the clk1(n) is connected to the clk_n pin of the device ?
    Thank you ,
    Sree
  • FPGA Part number is EP4CE15F17C8N (Cyclone iV)
    However i find the reason that is naming of negative pin.
    Whenever define one of differential pin, tool generate name(n) automatically.
    After that i annotate back it to Design PIN.
    This is error happen.
    Can you teach me how to process differential PIN define correctly?
    David
    SreekumarR_G_Intel
    There are many ways you can do ; usually way i do is assign the signal I/O standard as "LVDS " and assign the xxx_p pin in the pin planner or assignment editor or qsf assignment, then xxx_n will automatically assign by the tool .
    Hope helps ;
    Thank you,
    Sree
