David_MD_KIM
7 years agoLVDS IO error
Hi, again I try very simple case as attached. But It is same error result. Please advice how to interface lvds IO input by primitives Thanks
SreekumarR_G_Intel
7 years agoThere are many ways you can do ; usually way i do is assign the signal I/O standard as "LVDS " and assign the xxx_p pin in the pin planner or assignment editor or qsf assignment, then xxx_n will automatically assign by the tool .
Hope helps ;
Thank you,
Sree
