14 years agolpm_divide, when is the output valid?
On a Cyclone IV I'm trying to use the lpm_divide module to divide an unsigned 22 bit numnerator by an unsigned 12 bit denominator. I've left the PIPELINE_DELAY parameter at 11, but I really need to know when my quotient will be valid. Using signaltap it appears that the quotient goes invalid after 1 clock cycle and becomes valid after 4 clock cyles!
This doesn't make sense to me at all. If it's a pipelined design, why do I get any invalid outputs at all? Why do I appear to get valid outputs after 4 clocks when the pipeline delay parameter is 11??? PS I've looked in the documentation and it tells me what throughput I can expect in a Stratix device, but what use is that to me?
