14 years agoYou results are only plausible in case of a timing violation, either exceeding the clock frequency assumed in timing simulation, or changing the input values at the wrong time. The latter can easily happen in simulation, if you change the input at an arbitrary time.
Pipeline delay of 11 sounds unusually high, I see a default delay of 1 clock cycle suggested by the Megawizard. By the way, what's your clock frequency?
