14 years agoThen the observed behaviour should never happen, presumed the design passes timing analysis. Also the SignalTap part must not create timing violations, of course.
P.S.: I assume, that you ignore the output before the initial state has propagated to the divider output, in other words for the first 11 clock cycles.
