Altera_ForumHonored Contributor14 years agolpm_divide, when is the output valid? On a Cyclone IV I'm trying to use the lpm_divide module to divide an unsigned 22 bit numnerator by an unsigned 12 bit denominator. I've left the PIPELINE_DELAY parameter at 11, but I really need to k...Show More
Altera_ForumHonored Contributor14 years agoMy clock frequency is 100 MHz and my inputs change at 10 MHz
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
