Long Placement Optimization Time
My current project's placement optimization phase is long (more than 20 hours).
Is there a way to speed this up by using more CPU cores? I noticed Quartus (v24.1) is configured to use only 25% of my CPU cores, even though I selected to use all cores under the "Parallel Compilation" setting.
- sstrell
What's your target device? What are your computer specs? How full is the design? Have you enabled any compilation options that will naturally take much longer, like aggressive performance or individual options in the advanced Fitter settings like increasing the placement effort and others?
- TingJiangT_Intel
Contributor
Hi there, is there any updates on this? you may check the optimization results in dashboard report to check if there is too many logic optimized away.
- TingJiangT_Intel
Contributor
Hi there, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
