limit due to minimum port rate restriction (tmin)
- 2 years ago
Could you please generate a report for the Minimum Pulse Width Violation timing and check the 'Required Width' for the Port Rate?
The 'Required Width' for the port rate depends on the IO standard set on the pin, representing the actual specification that can be applied to that pin. It's likely that the pin can only run at 74.38 MHz. You may consider changing the IO standard to enable a faster clock.
There are limitations I can observe based on the screenshot alone, particularly regarding timing issues. It is recommended to share your design by archiving the project (Project > Archive Project) so that I can further investigate and debug it.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Richard Tan
Hi Richard Tan,
Thanks for the response!
I actually tried it yesterday from 3.3v LVCMOS to 3.3v LVTTL. Now timing is meeting and no violations.
But somehow ping is not consistent yet. Checking what could be the cause.
