roy970509
2 years agoJTAG connection Issues with Intel FPGA Development Environment
Hello, I am currently encountering some issues with my Intel FPGA development environment and would appreciate assistance. I am using Quartus Prime Pro version 18.1.2.277, and the device in use is t...
roy970509
2 years agoThank you for your response. I'm curious if my understanding is correct that 'Hardware Settings' and 'Remote JTAG' refer to different configurations. Additionally, I'd like to inquire about the issue with the board test system (BTS). I'm encountering an error when running BTS, and despite following all the provided instructions, the problem persists. The error message is as follows:
Failed to register GUI application!
Please make sure the following settings are correct:
-Make sure device list on JTAG chain is correct.
-Only one application instance is opened.
-All service is closed which is opened or claimed by system-console.
-Connect the board through on board USB-Blaster II.
If all settings are correct and still have the problem, you can try the following methods and then restart this application:
-Lower Jtag Clock with "jtagconfig --setparam <cable> JtagClock <value>" command.
-End java and jtagserver.exe process on Windows Task Manager.
-Power cycle the board.
-Restart your computer.
-Reconfigure the system MAX image.
sstrell
2 years agoRemote JTAG is having the board connected via USB blaster to a computer in one location (a JTAG server) and then you access it remotely from another computer. You don't seem to be doing this. Just go to the Hardware Settings and make sure the direct connection works.
