JTAG connection Issues with Intel FPGA Development Environment
Could you-
1.Download the BTS installation from our website: https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/stratix/10-tx-signal-integrity.html
select ES2 (if you are using an ES2 version of the board). Once downloaded please try to update with the following .pof
\examples\max5\max5.zip\system_max5\output_files\max5.pof
2. Please restart computer and power cycle the dev kit before you configure.
Let’s see if these works.
Another solution that you can try is apart from above, lower the JTAG frequency to 16MHz.
Aiman
Thank you for your response.
I'm curious about which version you're referring to as ES2.
I have been running the program with the file in the red box so far. Should I proceed with the file in the blue box?
Additionally, I tried lowering the JTAG frequency to 16MHz, but it was not successful.
