JTAG connection Issues with Intel FPGA Development Environment
Are you trying to do remote JTAG, because that is what is showing as failing. In the Programmer Hardware Setup, go to the Hardware Settings tab instead and select the USB Blaster from the pop-up list. That should do the trick. Your jtagconfig output means that you're seeing the device.
Thank you for your response. I'm curious if my understanding is correct that 'Hardware Settings' and 'Remote JTAG' refer to different configurations. Additionally, I'd like to inquire about the issue with the board test system (BTS). I'm encountering an error when running BTS, and despite following all the provided instructions, the problem persists. The error message is as follows:
- sstrell2 years ago
Remote JTAG is having the board connected via USB blaster to a computer in one location (a JTAG server) and then you access it remotely from another computer. You don't seem to be doing this. Just go to the Hardware Settings and make sure the direct connection works.
