nama828's avatar
nama828
2 years ago
Is DDR5 phy-only IP available?
Hi! I'm using Agilex 7 M-series (AGMF039) and Quartus Prime Pro 24.2. I'm looking for DDR5 PHY-only IP, but I couldn't find it in the EMIF IP. However, I confirmed that PHY-only mode is provided f...
  • AdzimZM_Altera's avatar
    2 years ago
    Hi nama828,
    "1. Is there a plan to release DDR5 PHY-only IP? If so, could you provide a rough release date?"
    • Yes, there is plan to support PHY-only mode in EMIF IP for Agilex 7 M series device but the release date is not yet confirmed.
    "2. If I modify the EMIF_DDR5 IP to use it in PHY-Only mode (e.g., emif_ph2_620), can it be synthesized and ported to the FPGA?"
    • No, because the EMIF IP is using harden circuitry.
    Adzim
