UserID4331231
8 months agoIOPLL related clock constraints
Hello Every one I am struggling with creating clock constraint and need help. I have agilix 10 FPGA design at project level top module I have input "iopll_clk_clk". this input is mapped to clo...
sstrell
8 months agoAgilex 10 is not a current device family (I presume you mean Agilex 3, 5, 7, or 9), but assuming you are using some Agilex device, simply remove derive_pll_clocks and remove that create_generated_clock constraint. The tool automatically derives PLL output clocks for these devices so no need to add the constraints. You can even remove create_clock because the IP has you specify the reference clock anyway.
And you said the PLL output pin was iopll_0_outclk0_clk, not iopll_0_outclk0, so that's probably why you're getting the warning.
