roeekalinsky
Contributor
2 years agoIOPLL non-dedicated feedback option doesn't work correctly
In Stratix 10 and Agilex, the IOPLL supports an option for using a non-dedicated feedback path when using the normal compensation mode or source-synchronous compensation mode. However, the non-dedica...
AqidAyman_Altera
2 years agoHello Roee,
As far as I understand, I'm sorry to inform you that the internal team's plan for now is not to proceed with the fix unless we get a request for a patch which will also be going through evaluation before we can move forward.
I appreciate your input on this issue and report it to us.
What I can help for now is to issue an update for the documentation and see if we can get a documented clarification on this.
Aqid
