roeekalinsky
Contributor
2 years agoIOPLL non-dedicated feedback option doesn't work correctly
In Stratix 10 and Agilex, the IOPLL supports an option for using a non-dedicated feedback path when using the normal compensation mode or source-synchronous compensation mode. However, the non-dedica...
AqidAyman_Altera
2 years agoHi Roee,
The internal team is looking into this, and it may take some time as there is no root cause for this issue. May I know if this issue is blocking you or not? Do you need a patch for this?
If yes, I will need to initiate an email to you asking for the detailed information to proceed with requesting a patch.
Aqid
