Intel MAX 10 on-chip Flash Memory IP core
I want to use in my project the IP core for tje on chip flash of the MAX10 FPGA. I will use the Quartus Lite edition. will I be able to generate NON time limited config files? Or should I buy a license to use the IP core without limitations?
Thank you.
- sstrell
I don't think you need a license for that core, and you can use Lite. Easy enough to try. Just compile and see what Quartus says.
- tehjingy_Altera
Hi
As what the previous comment mentioned.
The core does not need a special license to work.
You could use the IP in lite version.
Jingyang, Teh
- tehjingy_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
