nyquist0102
2 years agoIntel MAX 10 on-chip Flash Memory IP core
Hello, I want to use in my project the IP core for tje on chip flash of the MAX10 FPGA. I will use the Quartus Lite edition. will I be able to generate NON time limited config files? Or should I bu...
sstrell
2 years agoI don't think you need a license for that core, and you can use Lite. Easy enough to try. Just compile and see what Quartus says.
