TKlei11
2 years agoIntel LVDS Serdes Receiver removed input pins after compilation
Hi, I'm trying to read out data from an 12 bit LVDS ADC using the Intel LVDS SERDES IP. The IP is configured as a 9 channel RX DPA-FIFO with an Serdes Factor of 6. I'm using bit slip for alignment...
TKlei11
2 years agoAdditional note: After disabling bit slip in the SERDES IP it seems to work. However I need the alignment.
I'm using the following state machine for handling the bit slip:
proc_bitslip: process(rx_coreclock, rst_i)
begin
if rst_i = '1' then
bitslip_ctrl <= (others => '0');
bitslip_rst <= (others => '1');
bsctrl_state <= idle;
frame_locked <= '0';
elsif rising_edge(rx_coreclock) then
bitslip_rst <= (others => '0');
case bsctrl_state is
when idle =>
if rx_out(53 downto 48) /= "111111" or rx_out(53 downto 48) /= "000000" then -- sync pattern
bitslip_ctrl <= (others => '1'); --pulse bit slip ctrl
bsctrl_state <= wait0;
else
frame_locked <= '1';
end if;
when wait0 =>
bsctrl_state <= wait1;
when wait1 =>
bsctrl_state <= wait2;
when wait2 =>
bsctrl_state <= wait3;
when wait3 =>
when others =>
end case;
end if;
end process;
