16 years ago
Incremental compilation
Any one who's working with quartusii software knows anything about the function of Incremental Compilation? I am developing a giant system, and I am having a BIG Headache about the totally recompilaton of the hole project. This costs me plenty of time. So I am seeking for help that somebody could enlighten me the way to use incremental compilation. THANKS VERY MUCH!~~~~~~
    --- Quote Start ---
    --- Quote End ---
    can you expalin how big your design will be ? Compile runtime depends on a lot of things.
    E.g. device utilization, timing constraints , design size, .....
    Kind regards
    GPK
    --- Quote Start ---
    Kind regards
    GPK
    --- Quote End ---
    Thanks, the major problem I am encounting is that when I finished the partition assignment, and set the unchanged partition with the netlist type of "post-fit",but after the recompilation, the software still fitted the all design again, I don't see the meesage of "using the previous netlist" which shows in the Altera DEMO, and the fitting time doesn't reduce.......
    Kind regards
    --- Quote Start ---
    Kind regards
    --- Quote End ---
    did you define a fix LogicLock Region for all your design partitions ? Which Fitter preservation level did you choose ?
    After the elaborate step you should get info's like:
    Info : x design partitions requires synthesis
    or
    Info : x design partitions do not require synthesis
    Expand the message, maybe you get a hint what is wrong.
    Kind regards
    GPK
