--- Quote Start ---
can you expalin how big your design will be ? Compile runtime depends on a lot of things.
E.g. device utilization, timing constraints , design size, .....
Kind regards
GPK
--- Quote End ---
Thanks, the major problem I am encounting is that when I finished the partition assignment, and set the unchanged partition with the netlist type of "post-fit",but after the recompilation, the software still fitted the all design again, I don't see the meesage of "using the previous netlist" which shows in the Altera DEMO, and the fitting time doesn't reduce.......
Kind regards
