--- Quote Start ---
Thanks, the major problem I am encounting is that when I finished the partition assignment, and set the unchanged partition with the netlist type of "post-fit",but after the recompilation, the software still fitted the all design again, I don't see the meesage of "using the previous netlist" which shows in the Altera DEMO, and the fitting time doesn't reduce.......
Kind regards
--- Quote End ---
did you define a fix LogicLock Region for all your design partitions ? Which Fitter preservation level did you choose ?
After the elaborate step you should get info's like:
Info : x design partitions requires synthesis
or
Info : x design partitions do not require synthesis
Expand the message, maybe you get a hint what is wrong.
Kind regards
GPK
