15 years agoIncremental compilation problem
Hi, I developed a project using incremental compilation. I used some signalprobe to debig the systems, and now i need to make a modification to the code and then recompile but the partition merge gives the followin warnings.
Warning: Forced partitions to use the same Netlist Type setting due to Engineering Change Order (ECO) modifications that span multiple partitions Warning: Partition "Top" will use Post-Fit or Post-Fit (Import-based) Netlist Type -- Engineering Change Order (ECO) modifications will be discarded Warning: Previously generated Fitter netlist for partition "Top" is older than the current Synthesis netlist, but using the previous Fitter netlist because of the Post-Fit (Strict) Netlist Type setting what can I do to recompile the project? Thanks
