15 years ago --- Quote Start --- Plets, I tried to archive the project and then restore it and ot works... I added some code and made some test with signal probe and again after 3 or 4 signal probe compilation when i added more code the project was blocked... archived again and restored and it works... this is very strange. What does the archiving process delete form the project? --- Quote End --- Hi, my assumption was that all ECO changes will be skipped in case your archive a project. It looks like that it works, but of coarse it is only a workaround. As I mentioned before I think it is an Quartus bug. BTW: Did rum some tests with my attached projects ? Kind regards GPK
