15 years ago --- Quote Start --- OK! Sorry I gave the same answer two times... I will let you know --- Quote End --- hi, it is ( at least in my point of view) a bug in version 9.1. If possible change to version 10.0. I run my testcase and it looks like that it is ok now. The behaviour makes more sense to me. After you run a full compile all your signalprobes are disabled. You have to enable them and run a signalprobe compilation. In case you have a probe on a node which is not longer in your design you got an error. I think you should try it. Kind regards GPK
