15 years ago --- Quote Start --- Hi, i did it but nothing changes...and it happened again on another project... is there the possibility to discard all eco modification? --- Quote End --- Hi, strange ....., but ok. Maybe I'm not doing the same. I have two projects attached. I did following steps: 1. Run with top and subpartition set to "source file" 2. Set both to Post-fit , Placement & routing 3. Definiton of two signalprobes ( one for TOP and one for subpartition) 4. Run signalprobe compilation 5. Set Top back to "source file" In 9.1 I got the warning that the old netlist is used, but 10.0 synthesized Top new and disabled the signalprobes. Have a look to both project. If you can reproduce your problem in the 10.0 project post it back again. BTW.: It looks like that you get rid of your problem when you archive your project and restore it again. Kind regards GPK
