10 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and fail whenever the above error is written to stdout.
According to https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01272015_37.html this should (or maybe that was a fatal version?) have been fixed in 15.0. Any ideas to get around the problem or if it will it be fixed in 15.1?11 Replies
I had same problem.
wbgreen's solution seemed to be correct answer. but, it didn't work. so, I restored .bak files one by one except 'libccl_curl_drl.so.bak' I don't know why, Quartus Prime goes well. Anyone knows about this?
